John_Admin 388 Report post Posted July 25, 2016 Canon G1000, G1400, G1900, G2000, G2400, G2900, G3000, G3400 G3900 Series printers. Cause 5B00 Printer error has occurred. What to Do Contact your nearest Canon service center to request a repair. If You are technician You can reset 5B00 Error by Yourself using Canon Service Tool for G1000, G1400, G2000, G2400, G3000, G3400 printer models. As soon as we have it - we'll place it here - http://www.2manuals.com/index.php?cPath=99 Here You can read how You can repair Your printer by Yourself. This relates to Canon G1000, G1400, G2000, G2400, G3000, G3400. 1. Make sure Your printer is turned on. If the printer cannot be turned on, unplug it and go to step 4. 2. If an error has occurred, press printer's RESUME/CANCEL button. After the Alarm lamp is turned off, go to step 3. If the error is not cleared, press ON button to turn the printer off, and then unplug it. If the printer cannot be turned off, unplug it. Go to step 4. 3. Set printer to transporting mode. Press and hold RESUME/CANCEL button, and then release button when Alarm lamp flashes 8 times. The printer is set to transporting mode and turned off. Unplug the printer. 4. Make sure that cartridge holder has moved to far right. If the cartridge holder is not to the right, move it to far right. 5. Make sure that tank caps are properly closed. 6. Retract the paper output tray and output tray extension, and then close the paper support. 7. Unplug the printer cable from the computer and from the printer, then unplug the power cord from the printer. 8. Use adhesive tape to secure all the covers on the printer to keep them from opening during transportation. Then pack the printer in the plastic bag. 9. Attach the protective material to the printer when packing the printer in the box. If You have any problems You can post here. Share this post Link to post Share on other sites
John_Admin 388 Report post Posted August 11, 2016 We are working on updating WIC Reset Utility. New version will support Canon G1000, G1400, G2000, G2400, G3000, G3400 printers Waste Ink Counters reset. It will be so easy as for Epson models: 1. Run WIC utility 2. Buy Reset Key 3. Reset Waste counters in 20 seconds! Share this post Link to post Share on other sites
soheil 0 Report post Posted August 15, 2016 hi when wic support this modele printers thx and service tools v3600 canon support pixma-mg5470 Share this post Link to post Share on other sites
John_Admin 388 Report post Posted September 26, 2016 Canon G1000, G2000, G3000 printers will be supported in WIC New Version. Coming soon. Share this post Link to post Share on other sites
John_Admin 388 Report post Posted October 9, 2016 New WIC Reset Utility Version V5.0.10 support all Canon G series models: Canon G1000, G1100, G1400, G1900 Canon G2000, G2100, G2400, G2900 Canon G3000, G3100, G3400, G3900 Please download the LATEST version of the WIC reset utility here: For Windows OS - http://www.2manuals.com/WIC/WICReset.zip For MAC OS - http://www.2manuals.com/WIC/iWIC/iWIC.dmg For Waste Counters Reset it requires One Time Reset Key. You can buy it here http://www.2manuals.com/product_info.php?cPath=56_92&products_id=1138 Share this post Link to post Share on other sites
John_Admin 388 Report post Posted October 11, 2016 You have to put printer in Service Mode before using WIC. If You have already tried some other Service Tool ST V4720 or other versions - You could damage logic cirguit and printer will not enter Service Mode anymore. In this case you have to reprogram printers firmware and EEPROM by hardware chip programmer. Share this post Link to post Share on other sites
reniel0018 0 Report post Posted October 17, 2016 I tried using WIC, then I entered service mode, but after the process, the printer is still not working, I restarted the process from the start, turn off the printer and entered service mode again, But unfortunately, I pressed the keys incorrectly, then after that, my printer won't turn on. Could it be that the logic circuit is damaged? If yes, what am I suppose to do? Thank you Share this post Link to post Share on other sites
John_Admin 388 Report post Posted December 22, 2016 You have to reprogram EEPROM IC Share this post Link to post Share on other sites
00goory 0 Report post Posted August 4, 2018 Is this program still working properly? My printer Cannon G3900 doesn't work for error 5B00. Share this post Link to post Share on other sites
Bayborean 0 Report post Posted May 9, 2019 My canon g3400 doesn’t pass to service mode, i want refundif possible. Buying an empty eeprom chip and replacing will help¿ Share this post Link to post Share on other sites
