Paper Feed Adjustment Detail
Set the minimum and maximum values to determine the range by using the slider or text boxes.
Between the minimum and maximum values, five values will be determined for the sample feeding value. These five values will be shown above the Sample Prints button.
To use a specific image as Sample Prints to choose the most appropriate media, click the radio button next to User Defined Image, then click Browse to find the image.
The available size for User Defined Image is within 4060 x 1190 pixels and 24 bit BMP file format.
To use a standard image, leave the radio button as it is.
Click Sample Prints. The five samples determined even between the values you specified in step 1 will be printed.
Observe the samples and determine which image has the least amount of banding. A value is printed next to each image.
Repeat steps 1through 4 until the banding are eliminated.
Write down the value you determined.
Click Close and enter in the text box in the original menu the value you wrote down.
Previous
Next
