Activate Custom Paper
Activate a custom paper setting saved to the printer.
If you use this menu, all users who use the same printer will be affected. Notify all users of the same printer of any changes made.
 Select the number and the name you have set to the printer from the Custom Name list box. Respective parameters will be shown.
 If you are not satisfied with all parameters, click Edit to go to the Custom Paper Setup menu.
If you select STANDARD, the parameters will be disabled and each print job setting will be used.
If you select STANDARD, the Edit button is disabled.
If you want to disable the custom paper setup, select STANDARD in the Custom Name list box.
If you are satisfied with all parameters, click Activate. The parameters will be applied to all the print jobs.
